Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1158 Fragen Alle anzeigen
sim reader is screwed
hi
i just encountered this site and u guys are doing a fabulous job.
i have an issue with my iphone from past 3 months.
i did not used it because i dont know how to fix the p[roblem.
the problem is that one of the strings in the sim reader is displaced from its actual position. when i insert sim tray the bottom part is broken and was struck in there. i can see the metalic part of the reader through the vent.
i think replacing sim tray will resolve the issue but i cant find a tutorial to replace it.
i really appreciate if some one could post a tutorial for fixing this.
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
well, have a look at the teardown - it should help.
at http://s1.guide-images.ifixit.com/igi/ZC... you see the mainboard with the sim holder - should be fixable if the original contacts are still ok, but you my not be able to remove the sim card depending on your fix.
War diese Antwort hilfreich?
Bewertung 2
The sim card does not activate when I put the sim card in the phone. I have replaced the tray with a new one but it still does not read it? Can you help me?
Otis Hughes
812-655-1881
Bewertung 0
1 Kommentar:
My note 2 is doing same thing n it was working just fine, then i switched sim cards n now it wont read sim, help plzzz if u know how??
von
Antwort hinzufügen
umesh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 2,885
