Zum Hauptinhalt wechseln
Der PowerMac G5 ist ein Desktop-Computer, der erstmals 2003 von Apple Corporation produziert wurde. Diese Anleitung zeigt dir, wie du den PowerMac G5 (Modellnummer A1047, EMC: 2061, von 2004) reparieren kannst.
197 Fragen Alle anzeigen
Frage geschlossen
Requests - Step by step to remove "Memory Heat sink"
Hi all,
My wish is a "Step By Step"- guide for changing the memory "Heat Sink".
My fanspeed is going up and down, pending between 300 rpm - to 2000 rpm.
The computer has been running with both AHT and calibrated with ASD.
After lots of reading about "Fan noise Problems" and test and calibration I have found out that the memory heat sink is the problem. It is placed on backside of the motherboard, on a own board, and its not possible to see it with optisk viewe.
To change it, the motherboard must bee removed.
MY QUESTION IS:
- Do I have to remove the liquid cooling system, to remove the motherboard, or not?
- What parts, and what screws has to removed for getting the motherboard loose?
Please advice with experience.
NOTE:
After lots of reading I have find out that Fan-noise is a common problem on G5 power mac, especcially on G5 2 - 2,5 GHz (2004). On one of my G5/2,5GHz(2004) (have 3 G5 = 1.8 (2004) + 2.3(late 2005) + 2.5(2004) the fan go up and down, and the Memory Heatsink gives unrealistic high temp,(65° Celsius ) from the second G5 start.
I think its a accurancy-related-problem, on the memory heat sink.
Is it possible to by a Memory Heat Sink as parts?
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
i've tried to find anything about the memory heatsink - but i found nothing about it
since you are still searching for a solution i think the calibration with asd led to nothing
but i think you should contact me: markus.weiher@gmail.com
War diese Antwort hilfreich?
Bewertung 4
2 Kommentare:
Dubble thanks, great stuff to bee read about the G5 computers.
Markus is the "todays hero", i will say. I will know lots more about the arkitecture of a g5 computers now, only because of having the advantage of reading your answere and getting the mail, many thanks from me. :-)
von
hi göran,
i'm glad you could use the info ;-)
von
The memory heatsink is on the reverse of the logicboard. If you pull out the logicboard, then flip it over, you will notice a very long heatsink. It will be connected to the logicboard via plastic clips and/or a few screws and bolts. When these are taken off, then you can replace the thermal compound as i did in mine. it should drop the temperature by 10 degrees celcius (in mine it did).
Bewertung 1
I have a complete teardown/repair manual on PDF ......
edited a "problem" out
Bewertung 0
1 Kommentar:
Bewertung 0
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 2,944
