Zum Hauptinhalt wechseln
Modell M7886 / 450 MHz oder 500 MHz PowerPC 7400/7410 (G4) Prozessor
Is there a documentation for the power supply?
I haven't got a power supply for my Power Mac G4 Cube.
Is the 4 pin connector of the power supply documented somewhere so i can rebuild it?
Update
Hi!
Thx for your answer but as i wrote above, i don't have a power supply and therefore don't know a EEE number.
I'm looking for the electrical specs and the pin layout to re-build a power supply by myself.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
2 Kommentare
How can you re-build it if you do not have it? What are you trying to accomplish? Are you trying to build a power supply?
von
Sorry, maybe my english is too bad. I intended to build one from scratch.
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
PowerMac G4 Cube 205W Power Supply
EEE Code Note: All Apple Power Supplys have a special three digit "EEE" code embedded in the Power Supply serial number which positively identifies the part. Please note that this is the serial number of the Power Supply, NOT the serial number of the machine. The Power Supply serial number is on a tag which has the format "xxxxxxxEEEx". The "EEE" code is the three letters immediately preceding the last digit of the serial number.
What's yours?
UPDATE
661-2455 or 661-2455 R or 661-2455U
email these folks to find out which power supply is needed for your machine
email us at sales@welovemacs.com with your machine serial number
It should cost under $60.00 on eBayhttp://www.ebay.com/itm/Power-Mac-G4-Cub...
or
Powerbookmedic: http://www.powerbookmedic.com/Power-Mac-...
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Thx, i'll have a look to my S/N, when i'm back @home on the weekend.
To look on ebay: Will it be an issue, that i need an inlet for 230V/50Hz and not for 110V/60Hz? In other words, is the power supply universal for worldwide voltages?
von
All Apple power supplies will work on either 110 or 220.
von
kai, the pinout for the 4 connector plug is as follows:
A = +28V
B = +28V
C = Common (or - side of supply)
D = Common (or - side of supply)
the outer shell of the connector is ground.
Bewertung 1
5 Kommentare:
Thx! This is kind of, what i was looking for!
What does "Common (or - side of supply)" mean? (English is not my native language.)
von
kai, if you measure i.e. A and C you should get +28V same with B and D. They are common to A and B but not ground, that is provided by the outside of the connector.
von
Ah, understand. Thx a lot!
von
Do I need to connect the metal surround to anything? Earth or common?
von
@smnbldwn the outer shell of the connector is ground (Earth)
von
Antwort hinzufügen
kai wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 42
Insgesamt: 4,613
