Zum Hauptinhalt wechseln
How do I fix the earpod plug-in
Hi
I have a chromebook and it comes with this case from school. I have apple earpods and I leave them pluged in whenever I put them in the case. When I took out the laptop, I unplugged the earpods and the part that you plug in was bent and uneven with the cord. When I got home the audio was very bad when I tried it. Then I tried pushing it back in by bitting it, then it broke off.
Can you please tell me how to attach it back on and have it still just like before?:)thanks
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
luna, if you know how to solder, you can replace the 3.5mm audio plug. The repair should be similar to any audio jack repair. Something like this should give you an idea. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
Thats not possible to repair. You just need to buy a new pair.
Bewertung 1
1 Kommentar:
It's better to say You still don't know how to do it.
von
http://www.youtube.com/watch?v=zqyVUHv4A...
Bewertung 1
Antwort hinzufügen
luna wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 9
Insgesamt: 24,086
