Zum Hauptinhalt wechseln
Frage geschlossen
this computer can only take 3GB max.
I ordered 2x2GB sticks before I knew better, only to discover that this computer can only take 3GB max. Fortunately, I was able to return one of them and kept one of the original 1GB sticks in the other slot, for a total of 3GB (which works fine).
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
4 Kommentare
What do you mean by "interleaf" when using two 2GB sticks?
von
Maybe this will help explain Wiikipedia - Interleaved Memory
von
Thanks for the link. Do the two sticks have to be the same brand for it to work, or just the same capacity?
von
You want a matched pair (same brand & series)
von
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Your system can support both 2GB sticks, yes it will only use the 3GB. But that 1GB loss offers interleaf were as using the one 1GB & one 2GB sticks loose that. Don't forget to update your EFI firmware.
War diese Antwort hilfreich?
Bewertung 1
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 142
