Zum Hauptinhalt wechseln
Why does the Graphics resolution goes down to 8bit when adding RAM
My doughters pc, Compal-Zitech FL90 x64bit system have a strange problem. It does not accept more than 2 G DDR2 RAM. When adding 2 G more ( max 4 G byte) the Graphics resolution goes down to 8 bit with either Vista or Windows 7, but it Works fine with XP!!!
I have tried all triks and now i am start thinking of defect mother board/chipset etc. Anybody knows what is wrong?
Original Windows is XP, but she bought it brand new with vista installed. it is Worked with 4 GBytes with xp 32.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would check in the BIOS it sounds like the memory reserved for video is being disabled when you add 4GB because it removes the video memory to be used as system memory.
The limits of a 32bit system is 4GB Total include Video Memory in that due to Hardware mappings.
Note that memory on our graphics cards DOES NOT COUNT towards the physical memory limit because it does not occupy address space as seen by the CPU. However, hardware mappings do. A graphics card with 2GB of memory on it will probably not have more than 256MB of mappings if the BIOS has memory remapping disabled (which it should for a 32-bit OS). That's why the physical memory limit is typically around 3.5GB, even if you have a graphics card with 1GB -- hardware mappings seldom exceed 768MB.
There should be a setting in BIOS that lets you force more memory for video and let you increase the resolution above 8 Bit
Also note that installing a 64 Bit OS would also solve this problem
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
MKA wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 1,501
