Zum Hauptinhalt wechseln
A new iteration of the set-top box, a side-set box. Chromecast connects to your Wi-Fi network to stream content from your compatible device to your television.
11 Fragen Alle anzeigen
Broken hdmi on chromecast, can it be repaired?
Someone tripped on the wire, snapping the hdmi part nearly off. Now it receives power, but cannot output sound or video. Is there anyway I can repair this?
Ist dies eine gute Frage?
Bewertung 15
Einen Kommentar hinzufügen
12 Antworten
Hilfreichste Antwort
Its a mild long shot, but probably what happened is some of the connections have come loose from the board inside. I bet it broke from the left side, leaving the right side connected as that where the power is. First you'll have to crack it open and see how bad it looks inside. Maybe take a picture if you'd like and send it over and I can judge from there. If it looks possible you'll probably need to make little jumpers from the connector to the board using bits of leftover wire. It won't be fun and you'll need a small tipped solder iron to do some(steady hands help too) but hey you keep it outta the landfill. Good luck.
War diese Antwort hilfreich?
Bewertung 3
A shelf fell on my Chromecast , bent the HDMI connector on it and stopped working. I inspected the hdmi end of the Chromecast and about 7 pins inside that end had bent. I popped the case open, carefully wiggled the black plastic connector off of the pins. Then straightened the pins with a tweezers, carefully reloaded the pins back into the connector. Success! Now it is connected via the short HDMI cable that came with the Chromecast.
Better to be lucky than good.
Bewertung 2
1 Kommentar:
would i use a tweezers to connect all of them that came off. pulled 1st gen off tv hdmi head stayed plugged in
von
My hdmi chromecast got bent as a L form when my kid pushed the TV backward. Tv was ok.
I crack open the cast and notice that half of the HDMI connection was separated from the cast board. So I bend it back straight making sure that the connections was touching the board properly but did not solder it cause it takes time and extra effort. What I did i added the extension cable that came with the cast and use duck tape to make it stay straight cause it was wobble a little bit.
Glad to say that I have a perfectly working chromecast, the only downside is that is a little bit longer that before cause of the extension cable. But hey I'm happy it works :)
Bewertung 1
This is the part needed to fix it.
uxcell 10PCS 1.0mm Female HDMI Jack Socket 19Pins 4 Legs DIP 180 Degree https://www.amazon.com/dp/B00OKDVMQY/ref...
Bewertung 1
3 Kommentare:
Do you have a video on how to replace it?
von
Thanks for the link, that's exactly the part I needed.
von
Can anybody tell me the wire diagram for for the male hdmi. I have chomecast 3 . Thanks
von
My HDMI connector also came off the chromecast, exposing about 14 wires.
Here's a jpg on Microsoft Onedrive: http://1drv.ms/1wQCtUt
Can someone advice the best course of action?
Thank you.
sfguy2 (at) gmail.com
Bewertung 0
1 Kommentar:
Same here. Did you fix it?
von
I have this problem with my devise too
Bewertung 0
You can buy a new connector and replace it:
http://www.ebay.es/itm/-/192106024898?
Regards!
Bewertung 0
1 Kommentar:
it is no more available :(
von
Help my problem is that the cable was cut in half, but I had to replace the HDMI connector with a generic one and I need help to join the mini colored cables with the new HDMI as they are not the same color
Bewertung 0
  1. J'ai installé chromecast. Sur netflix et you tube j'ai l'image et le son. Sur d'autres sites notamment de streaming et dailymotion, je n'ai que l'image. Solution. NB j'ai installé l'appli home.
Bewertung 0
You can buy new HDMI pin and replaced the broken one
Bewertung 0
I also have same problem but I able to fix it by replacing the HDMI
Bewertung 0
1 Kommentar:
what's the name of the connector you used?
von
Chromecast is not working
Bewertung 0
Antwort hinzufügen
Kindal Dewitt wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 16
Letzte 30 Tage: 70
Insgesamt: 34,162
