Zum Hauptinhalt wechseln
1,83 GHz Core Duo oder 1,83, 2 oder 2,16 GHz Core 2 Duo A1208 (EMC 2104/2110/2114/2124)
201 Fragen Alle anzeigen
Can I transfer my data to new hard drive?
Hello. I want to upgrade the hard drive of iMac (17" Late-2006) from 160 GB to 500 GB. I want to copy the old hard drive as it is, onto the new hard drive (including all the files and set up).
Please suggest any software or tip to do that.
Thank you.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Do you have a second Mac and a FireWire cable? If you do you can connect the two systems together setting up your old system in Target mode. With the second system have the new HD connected via FireWire or USB adapter or case so you can then use the OS's copy function.
You can also use Time Machine making a backup copy of your drive and then restore it to your new HD. Doing it this way you can install a fresh copy of your OS Vs an image of your old.
There are a few cloning apps out there as well like Carbon Copy Cloner or Super Duper both will cost you to get the better versions and you still end up needing to address the hardware setup to connect your new HD (see above).
War diese Antwort hilfreich?
Bewertung 2
You can use an external hard drive and transfer your data on there
Bewertung 0
Antwort hinzufügen
Raz wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 533
