Zum Hauptinhalt wechseln
iPad Mini mit 7,9 Zoll Display und 16, 32 oder 64 GB Speicherkapazität.
630 Fragen Alle anzeigen
Ipad mini wont charge after screen repair
replaced digitiser all working perfectly - but wont charge with known working charger/s...tried 3 different chargers.
Ist dies eine gute Frage?
Bewertung 0
Einen Kommentar hinzufügen
4 Antworten
Well if u have tryed another charger or cord,and u no that aint the problem,and wrk was done recently,could of left something inside unplugged,it can happen,must take aprt and see,or if done at a shop ,call them tell them whats up,make sure port were u connect charger is tight and not loose,or moving alot,could be charger or one side broke off motherboard and may need soldering,k,but goodluck
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
I repaired it - but I'm a repairer, with many years ex and many hundreds of devices repaired. nothing unplugged inside. wont register when plugged into macbook also doesnt charge.
von
Check for missing small resistors near where the battery connects to the logic board. They can very easily be scraped off even with a finger nail while you are disconnecting the battery. If so, you likely will not be able to find the resistor. As a last resort, you could try bridging the two points with a solder ball.
Bewertung 0
Michelle is correct there is a resistor right next to the battery port that probably got knocked off. I'm having the same problem.
Battery says charging but remains at 1% after digitizer replacement
Bewertung 0
Hi there
i think i found this proble and have been able to take a picture of this. I have the same problem and need to find out if there is a posible way to solder this my self.
Bewertung 0
Antwort hinzufügen
Seanne Chamberlain wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 1,131
