Zum Hauptinhalt wechseln
Die Nintendo Wii Spielekonsole erschien Ende 2006 und wurde bis 2011 produziert.
How do you fix error message and noise?
I have taken this wii apart 3 times now and am still unable to troubleshoot this problem. The menu and stuff will work but when you put a disk in, it will start spinning, but when it tries to read it, it makes a noise that repeats. The best way I can explain the noise is "cli-chunk cli-chunk cli-chunk" (I have looked on YouTube but find only grinding noises from bent metal, I also tried cleaning the lens twice with no success and it was not dirty inside showing it wasn't used much before it broke). After about 20-25 repetitions of the cli-chunk sound it says "An error has occurred. Press the Eject Button and remove the disc, then turn the Wii console off and refer to the Wii Operations Manual for help troubleshooting" I am thinking it might be a motor for the disc drive lens based on the noise, but I don't know how to see what it is doing when it is running if i don't have a clear disc to put in.
Please reply ideas, suggestions, or fixes you have.
Ist dies eine gute Frage?
Bewertung 4
3 Kommentare
I fixed the wii, I never found the problem, but I decided to replace the entire disc drive unit.
von
I just need help please anybody I want to play my Wii
von
Have you replaced the disk drive already?
von
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
You're optical drive has sagged into the games reach. Open it and pop it back up with a flathead and it'll be good as new!
War diese Antwort hilfreich?
Bewertung 1
4 Kommentare:
Can you be more specific with your fix? I dont know what you mean by games reach and what part of the optical drive?
von
Im still searching but i later found another user say that you clean the lens manualy (yes, open it up) because it jumpin all around that sh** trying to find the disc because it's currently blind.
von
No I tried cleaning the lens, multiple times, plus the noise doesn't show that the lens is even able to move.
von
Ok, final atempt at being helpful. Somebody said they found the laser pot. I have no idea where that is but it will help to turn it up. The other thing is that your laser may have burnt out. I had min since 2008 and mine was a dust pocket. That and i cleaned it a million times in one night with no luck so i feel you but still, refer to the last couple of sentences.
von
Any further explanation for this fix would be appreciated! I have the same problem. Is the tech saying to open the optical drive?
Bewertung 1
1 Kommentar:
Did you ever figure out how to fix this problem, I have the exact same problem, tried to clean it out (wasn't that dirty), I dissembled it and bent the metal tabs (https://www.youtube.com/watch?v=WaQabJd3...). Still "clicks" and shows the error message you described.
von
Antwort hinzufügen
Eric H wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 44
Insgesamt: 16,323
