Zum Hauptinhalt wechseln
Repair guides and support for small electric personal space heaters.
20 Fragen Alle anzeigen
Why is my eden pure blowing barely warm air?
I have a eden pure 1000xl heater. It is blowing out air and working well but the air is only about 75 degrees.
I can see the light is on but it is not very bright in comparison to my other eden pure heater. Is this a bulb issue? I am extremely handy but before opening the box I am looking for knowledge. The unit was manufactured in 0907.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
2 Kommentare
How to know if bulb is bad
von
My eden pure was only blowing cold air...so i bought all new tubes and put in it but it's still only blowing sorta warm air? I don't know what to do please help!
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The element is most likely burnt out. Here's a video on repairing it: http://www.youtube.com/watch?v=tSTHbLrUp...
War diese Antwort hilfreich?
Bewertung 2
If your EdenPURE 1000 XL is only blowing warm air, that is certainly a sign that one or more heating element bulbs need replacing. You can watch a video on this page that provides a step by step guide on replacement the heating elements in your heater. It’s very well done and the individual who provides the demonstration is an authorized edenpure parts dealer.
Bewertung 2
3 Kommentare:
Not only is it blowing warm air, but the fan speed is slower than usual as well. Is this still a heating element issue?
von
I have the same issue as Robert S. How can I fix this?
von
My blows cold air on one side and warm on the other side is that the way it should work or not
von
My Edenpure is making a high pitched whistling sound and after about 20 minutes, it cuts off. One time it kicked a breaker. What's up? What should I do?
Bewertung 0
1 Kommentar:
If you're edenng pure heater is making a high-pitched whistling noise after about 20 minutes it sounds like the bearings on the fan are out, causing the motor to trip the breaker. Replace the fan.
von
Antwort hinzufügen
mike wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 134
Insgesamt: 35,414
