Zum Hauptinhalt wechseln
The HTC Inspire 4G is the first smartphone available on AT&T Wireless branded as "4G". It's nothing more then an Desire HD locked to AT&T and running AT&T Software.
12 Fragen Alle anzeigen
How do you apply the 4 plastic pieces to LCD/Digitizer assembly?
I have a new LCD/Digitizer assembly that doesn't have the plastic pieces attached (the ones that light up the home/menu/back/search keys). How do those get put on without prying apart the new assembly?
Thanks in advance,
Jessica
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
You will probably need to transfer from the old unit. So whatever process you use to remove them from the old assembly, reverse to apply them to the new one.
War diese Antwort hilfreich?
Bewertung 0
Thanks David,
Right after I posted that, I decided to try peeling off the clear adhesive that was still on the old digitizer and apply it to the plastic tabs. Then I aligned them above each key (home, search, back and menu) and slid them into place, pressing them down with a thin piece of cardboard inserted between the lcd and plastic tabs. It worked out :o)
Bewertung 0
Antwort hinzufügen
Jessica wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 156
