Zum Hauptinhalt wechseln
The HTC One (codenamed M7) is HTC's 2013 flagship smartphone. It features a seamlessly designed unibody aluminum frame, large dual front-facing speakers, and a 4.7-inch 1080p display.
149 Fragen Alle anzeigen
Anyone figured how to replace Broken display glass?
This is the htc one, 2013 model. Is there a way to remove the damaged glass and glue a new one on without taking phone apart?
Has anyone tried an attempt yet?
Any input is appreciated, thank you!
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
No, this would be impossible. The glass is fused to the display and the digitizer, and disconnecting the cable requires removing everything.
War diese Antwort hilfreich?
Bewertung 0
It's definitely possible to separate the LCD from the screen but it requires professional separating tools(hot plate and other hardware it comes with). In the picture, is the mechanism you would need.
Bewertung 0
Antwort hinzufügen
erngoweignspdfomg wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 622
