Zum Hauptinhalt wechseln
Der größere von Apples MacBook Air Laptops mit Doppelmikrofon und 802.11ac Wi-Fi Konnektivität.
Enclosure for mid-2013 MacBook Air SSD?
Is there an external enclosure for the mid-2013 Macbook Air's new SSD? I removed the SSD from a non-operable device and would like to copy the files to a new drive. These have been available for the 2010-12 MacBook Air drives, but I'm confused about compatibility of current enclosures on the market and the new SSD for the mid-2013 model that was revealed by iFixit.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 4
1 Kommentar
MD760LL/A ModelA1466 (EMC 2632) with SanDisk SSD (SDNEP 655-1838C)… The Mother Board failed and I would like to recover the data off of the drive prior to selling it out for parts. Does anyone know of an adaptor that works for this model of SSD?
Any help would be greatly appreciated!
von
Einen Kommentar hinzufügen
10 Antworten
Gewählte Lösung
Sorry no there is no external case yet to house the new PCIe versions of SSD's Apple is using in the new '13 models.
With that said you could swap out your SSD with the spare (as long as you have the same exact model). Then, using a USB drive copy off all of the stuff to the USB drive then swap back your SSD unit and copy back over the stuff you need.
While this is a fair amount of work it shouldn't take to long to do. If you plan to get rid of the SSD I would put your MacBook air into target mode and via a second Mac wipe down the SSD before swapping yours back in.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hilfreichste Antwort
I had the exact same problem. My Mid-2013 MBA suffered severe water damage and the logic board is fried. I plan on having Apple send it off to have the innards replaced (which they quoted $280 if they detect no damage, $750 if the detect water damage). I asked if I they can A) recover my data for me before tossing the old SSD, B) Return the old SSD with the refurbished computer, or C) let me take out the SSD before they ship it off.
They refused all 3 options. They said if I don't turn in the complete computer, including the original SSD, I will not qualify for that repair rate that the quoted me. Apparently it's a subsidized rate to replace damaged parts, so if I turned it in with parts missings I would be charged a higher full retail price for the parts and repair.
I found a solution. Despite what everyone says, there IS an SSD enclosure on the market that works with the new SSD enclosures: It's called an Apple Macbook Air.
I bought another brand new identical MBA from apple ($1500). I took the SSD out of my damaged computer and put it in the new MBA. It booted right up as if it was my old computer. I copied all the data to my network drive. I very carefully put the stock SSD back in the new computer and closed it up very very carefully, sure to not leave a single scratch or trace the computer had been opened. I put it back in the orginal packaging and returned it to the Apple Store the day after it arrived in the mail for 100% refund, no restocking fee or anything.
I felt a tiny bit bad about abusing their generous return policy like this, but at the same time I feel like they really left me no choice. They offer no enclosures for their propriety SSDs and they wouldn't even send me back the SSD from the broken machine or do a quick copy of the data from the old SSD to the new one for me... or they could even offer to test the SSD and if it work keep the same old SSD (data intact) in the new logic board, and maybe even save them some money on parts.
Bewertung 7
I have the same issue for my nephew's Macbook - has there been any update to this? Is such a device available now where I can put the drive in to retrieve data?
Bewertung 1
6 Kommentare:
Thanks Dan. A friend shown me this site yesterday. I am UK based so am going to see if I can find a British seller before I commit to a purchase from abroad. Thanks for your assistance
von
So far they are the only ones. Gee, we're only across the pond mate! ;-} They do ship to farther off lands.
von
Haha! Yeah, I don't have a problem with that, it's just an urgency to retrieve the coursework. I have had an online chat with them, they are on pre-order, it's that new a product. Thanks for the help, it is appreciated.
von
OWC has great products. But be careful. Their Envoy Pro Enclosure doesn't work if your original Apple SSD (like mine) has Toshiba chips on it. My MacBook Air is a mid 2013 one and technically the enclosure works with my model. I guess Apple used different chips in their SSD's and it just so happens that the Toshiba ones don't work with the OWC enclosure.
von
1 weiteren Kommentar anzeigen
Are there any enclosures for Macbook Air Mid 2013, PCIe SSD with Toshiba Chips? It’s 2021 and I’m having some trouble finding this.
Bewertung 1
1 Kommentar:
There isn't as far as I can see. I have tried & returned two because neither worked. I feel we have been truly conned by Apple...when they outsourced this SSD to Toshiba.
von
Thanks. Unfortunately, my Air was the victim of clumsiness and suffered severe liquid damage. Just swapping out a drive isn't an option. Appreciate the response and I'll stay hopeful an enclosure will hit the market soon before I send the computer out for repair.
Bewertung 0
There are enclosures, however they normally come with SSD's to expand memory. If you do a google search for 'OWC', they have a lot of different solutions that might help... However I have not found a stand alone one either.
Shaun
Bewertung 0
2 Kommentare:
Shaun your right time flies, OWC now has SSD's & case solutions for most of the Air's & many of the retina MBP's. Sadly, the mid '13 model and newer of the Air is still MIA ;-{
von
The '13 and newer Air uses a different SSD based on PCIe as such the interface is unique from the older models.
von
It REALLLLLY sucks that this external case (CASE) is 100.00! When for a standard M.2 you can buy a 2.5" enclosure and simy reuse the drive in any PC but Apple's.dam proprietary style ssds make this irrelevant until.someone in China makes one which I'm sure won't be long. I want to put my 128gb INSIDE an older.2012 2.5" standard HD machine....granted it won't be quite as fast it'll still be better than an external option which I don't need at all.
Bewertung 0
I've got a 3D printer. Send me an adaptor board, and I'll return an enclosure.
Bewertung 0
Thus the OWC Envoy Pro enclosure is not compatible with all Apple Original equipment SSDs (https://eshop.macsales.com/Service/Knowl... )
Bewertung 0
For posterity’s sake, when my 2013 Macbook died I used this enclosure: https://www.amazon.com/dp/B08DFDX8WC/ref... Called “ACASIS USB C 3.0 Enclosure for Apple Flash PCle SSDs Supports for MacBook Pro with Retina Display mid-2013 and Later Models” on Amazon. The drive could not be seen by other computers when plugged in, but if I plugged it into my 2012 Macbook and changed the startup disk to it, I could boot up with it. Then, I just moved all my data onto a USB drive from there.
Bewertung 0
3 Kommentare:
I so wish this worked for me, I've feel truly cheated by Apple because my SSD is a Toshiba & I have yet to find a reader for it.
von
@katie stevens - Sadly some of the Toshiba drives had issues. Apple did have a recall for it but thats ended ;-{ Apple Recalls Mid-2012 MacBook Air For SSD Replacement – 64GB and 128GB SSD Systems Affected
von
Thanks Dan, I've only just seen your comment.
von
Antwort hinzufügen
Bob wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 26
Letzte 30 Tage: 71
Insgesamt: 24,322
