Zum Hauptinhalt wechseln
Informationen und Reparaturanleitungen für MacBook Pro Modelle mit 13 Zoll Displays.
9745 Fragen Alle anzeigen
Hinges have gone bad.
I believe my hinges have gone bad on my MacBook Pro. The display will occasionally flash and then look like stage lights shining up on the screen. Any suggestions on what I should do and can I fix it through items on ifixit?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
You need to obtain the recommended tools for opening the machine (every job is easier when you use the proper tools), Follow the guide to open the machine so you can tighten the screws on the clutches (Mac speak for hinges).
Before tightening back them out a bit and put a single drop of Loctite™ on the threads.
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
What about the display flaking out on me? Will tightening these screws help with that as well or is something else needed?
von
Check the condition and connector on the LVDS cable… I think the extra play is shorting your connection and once you get the slack out of it you should be OK - unless the slack has allowed the cable to be cut/nicked. If you see cuts nicks you could try using some silicone to seal the short. I wouldn't loctite the threads until I knew I didn't have to go back in and replace the LVDS cable.
von
Antwort hinzufügen
benandem98 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 216
