Liquid damage, temp sensor TPOP -- 124
The computer had water damage, some parts have been replaced. All the Apple resets known to man have been run. Now the fan spins full speed and the Apple hardware test reports 4SNS/1/C0000008: TPOP--124. I've found a few posts of people with the same error. Everyone assumes it's the logic but no one seems to be certain. The issue I have is that the logic board has already been replaced. My next guess is that it's in or near the track pad. Can anyone determine which component is actually failing from the hardware test results? Or point me in the right direction.
Ist dies eine gute Frage?
3 Kommentare
4SNS/1/C0000008: TP0P--124
T= Temperature
P= Power Bus.
*0P= *zero (is not O)
von Rene Velazquez
I have the same AHT error code.. any solution?
Did you replace the DC supply Board or the SATA cable?
Any other solution found?
von Rene Velazquez
My MBP is A1425 Macbook Pro 13 retina i5 120gb SolidDrive.
Same error 4SNS/1/C0000008: T POP--124
von Rene Velazquez
