Zum Hauptinhalt wechseln
No start tone, not booting up after install of Mavericks
I recently upgraded to Mavericks on my 2008 MacBook Pro. After install, every time i'd start it up, it took longer and longer to do so. I used it and shut it down at night and the next afternoon, it wouldn't start up. The hard drive is functioning, i've removed it and tested it, the sleep light stays lit up, theres no start up tone and the display stays black. Is this a logic board issue or would a RAM upgrade possible?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
2 Kommentare
Please give us the last three figures of your serial number.
von
Sorry for the delay, last 3 figures are
XA9
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This MBP has the infamus Nvidia 8600GT gpu that could be faulty.
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Yep, i'm guessing you're right on the money, i removed the RAM and turned it on, the Mac didn't even look for the RAM before it stopped booting. Logic board is dead, oh well, got 6 years out of it
von
Have you tried to clear the PRAM? (Command + Option + P + R immediately after powering on).
Here is a list of the POST and what happens before the boot chime. If you are not getting the boot chime then these are your problems. If there is no chime there is no issue with the HDD because at that point the system is not even looking for the HDD.
  • Black screen, power LED on - POST or BootROM failure
  • Flashing power LED once per second - bad RAM, no RAM
  • Three flashes, a pause, and three more flashes (occurs continuously) - marginal RAM
Bewertung 1
1 Kommentar:
@jkingsnorth
Thanks for that.
The screen stay black and power LED on.
Can this be rectified?
von
Antwort hinzufügen
Craig wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 527
