Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2193 Fragen Alle anzeigen
Grounding clip moving after battery replacement.
I replaced the battery in my 4S, it all went smoothly apart from one issue, the grounding clip that goes under the battery clip keeps moving, I lined it up as per the instructions, screwed in the the screw and while it is held in place it can be twisted very easily and moves on its own. I'm at a loss here and would really appreciate some help.
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
The battery takes two screws change them about you might have mixed them up
War diese Antwort hilfreich?
Bewertung 1
Check to be certain the battery flex connector is seated down in the logic board connector perfectly. When you carefully tighten the upper battery connector screw it will hold the clip in place, which is under the battery connector as you say. I have seen them movable, but not move easy or on its own. But even if it did move some, if everything is properly in place, I would not worry about it.
Bewertung 0
Antwort hinzufügen
Mary Ellen wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 188
