Zum Hauptinhalt wechseln
Fünfte Generation des iPhones. Die Reparatur dieses Geräts ist unkompliziert und mithilfe von Schraubendrehern, Hebelwerkzeugen und Geduld zu machen. GSM und CDMA mit 16, 32 oder 64 GB in schwarz oder weiß.
2201 Fragen Alle anzeigen
iPhone 4S does not get "Service" after battery replacement
I replace batteries in two iPhone 4S using the IFIXIT instructions. Both appeared to have had similar issues in that they could not get cellular service afterwards. One phone I was able to resolve using the date/time change method.
The other continues to be problematic. I have resat the connecters, verified the antenna is connected properly, replace the original battery, restored the phone. charged each battery to 100%, and turned in off and back on again like recommended in "The IT Crowd".
I notice that (besides no cellular service) the phone gets hot during charging on either battery. I don't get any overheat warnings or other functionality issues.
I know batting .500 isn't bad, but I am a bit of a perfectionist.
Thoughts? Solutions?
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Did you try turning on airplane mode then turning it back off?
War diese Antwort hilfreich?
Bewertung 0
1 Kommentar:
Would that have any effect since the phone was restored to factory?
von
It looks like your iphone read your battery does not exist, and the service provider you are working with the battery, try to plug the battery that would be used, replace the card provider you go back and try to connect to wifi or internet after your iphone is running and make sure that the setting of date & time you "set automaticlly". because without the battery you are going to default settings on the 1st of January 1970, this may help you, Thank you.
-Afriyadi-
Bewertung 0
Antwort hinzufügen
Jollymon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 241
