Zum Hauptinhalt wechseln
Sechste Generation der Apple iPhones, angekündigt am 12. September 2012. Die Reparatur des Geräts ist ähnlich derer älterer Modelle, Schraubendreher und Hebelwerkzeuge werden benötigt. Verfügbar mit GSM oder CDMA ,16, 32 oder 64 GB in schwarz oder weiß.
2522 Fragen Alle anzeigen
Battery will not charge after replacement
My iPhone battery has been shutting off at like 20% all the time so I figured I needed a new battery.....followed directions exactly while replacing my iphone 5 battery. The battery will not charge at all. The charging icon comes on and it makes a sound when plugged in but the percent wont go up at all. Put the old battery back in my iphone and the same thing. I tried a different cable...cleaned out the charging port....still same thing. It recognizes that its plugged in though. any ideas?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 0
1 Kommentar
Did you found a way to fix it? if yes, send info to my mail id, add.vignesh@gmail.com
von
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Had a iPhone 5 that was fake charging yesterday and a new lighting port solved the issue
Replace this before you dive into the logicboard damage
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
I tried to find the best picture I could find. Look above (about a cm in height) where the charger connector is at, there should be a few small towers. yea i don't think anyone discloses that info. You might be able to get it fixed by making a connection with a jumper pen.
Imei check Run the imei in the back of your phone. Most people have no idea that Apple warranties their phone for a whole year.
Bewertung 1
2 Kommentare:
You may have broken the Charger power tower (it's located right where the Battery connector is). I should know because it happened to me once. Check and see if it's still under warranty, if so get a replacement from Apple.
von
not under warranty any more. where is this "charger power tower" at? have a picture? this is BS considering i followed directions exactly. no warning/mention in instructions of the possibility of breaking the charging portion. the fact i was very precise in removing battery makes me think many people would have encountered the same issue I'm having.
von
Antwort hinzufügen
cetherid wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 3
Insgesamt: 2,264
