Zum Hauptinhalt wechseln
Repair guides and support for the 3rd generation Ranger, a compact pickup truck manufactured by Ford.
Transmission fluid—how many quarts to fill?
How many quarts of transmission oil for my 2005 Ranger 4WD?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
its a 1992 ford ranger 5 speed
von
patsymiller0, 1992 Ford Ranger 5 speed manual transmissionApprox 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
https://www.youtube.com/watch?v=AC8lhIcK...
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Raleigh, Ford says that the transmission holds 10 quarts on two-wheel drive models and just under 10.5 quarts for four-wheel drive models for a complete change.
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
08033530020 Mr ola
von
Four wheel drive
von
@Olayanju Suraju what make, model, year?
von
Uses less if you don't drain the torque converter.
Bewertung 2
2 Kommentare:
Well how manny qrts is less if u dont drain the TC??
von
Generally the tc holds about 4-5 quarts
von
Diese Antwort bezog sich ursprünglich auf eine andere Frage.
According to the Owner's manual :
2005 Ranger Auto Transmission Fluid - use Mercon V
4x4 with 3.0 and 4.0 engines use 10.3 Qts (9.8L)
Note the 4x2 uses 9.9 Qts (9.4L) with the 2.3L engine and 10.0 qts (9.5L) with the 3.0/4.0 engine
Bewertung 2
1 Kommentar:
2005 Ranger 4x4 with 3.0L or 4.0L engine takes 10.3 qts (9.8L)
Use Mercon V ATF
see page 233 of manual
https://www.fordservicecontent.com/Ford_...
von
Raleigh /patsymiller0, If a manual tranny, Ford Ranger 5 speed manual transmission Approx 2.65L/2.8quarts US of ATF Mercon V, video link below will show how it is done.
Good luck.
Bewertung 2
2 Kommentare:
How many liter atf for my ford everest 2005 model automatic transmission
von
How many for a 2000 4x4 ranger xlt with 3.0 engine and automatic transmission
von
Antwort hinzufügen
Raleigh wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 49
Insgesamt: 56,564
