Zum Hauptinhalt wechseln
Dritte iPad Generation, 4G fähig, Modellnummer A1430, erhältlich seit dem 16. März 2012. Die Reparatur erfordert Hitzezufuhr und vorsichtiges Hebeln.
Speaker sounds distorted at higher volumes
A few months after I bought my iPad, I noticed that at high volumes, sounds on the built-in speaker were distorted on all applications. It sounded like a blown speaker. I tried rebooting and restoring my iPad to no avail.
The interesting thing is that it only seems to be coming from the left channel.
I went to Settings>General>Accessibility>Hearing and was able to adjust balance.When I set the mixer to right only, the speaker sounds fine (but is only the right channel) It starts to sound distorted as I bring the left level up.
It sounds fine on headphones and bluetooth speakers, no distortion at all.
Any ideas for a permanent fix that allows me to listent to both channels at the same level?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
If its still under warranty take it to apple otherwise, it sounds like you may have to replace the speaker.
War diese Antwort hilfreich?
Bewertung 2
1 Kommentar:
Out of warranty. Speaker sounds fine if balance set to the right.
von
The speaker is damaged, probably by overloading it. It's not worthwhile to open/wreck an iPad to repair just the speaker.
Bewertung 1
Antwort hinzufügen
wresnik wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 51
Insgesamt: 8,143
