super drive ejects "hard"
I have a PowerBook G4 aluminum; I recently upgraded my hard drive. That went fine, but after putting the case back together, discs are ejecting hard from the superdrive. When i eject the disc, the drive kinda whirrs and the disc will barely eject. I noticed that the aluminum case just above the slit in the drive is a bit bent down (it is convex in the middle)...it may be that I do not have the keyboard secured well enough where it clips on the tabs on the case. I have taken it all apart, but still cannot get the tabs to grab on to the little latches. There does appear to be a bit of a gap between the case and the keyboard...i.e. it is not flush against the surface...thanks for any ideas here? could it be the drive going bad also?...HAs anyone ever seen this?
Ist dies eine gute Frage?
