Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1158 Fragen Alle anzeigen
What do the numbered ribbon cables do specifically?
I recently replaced a cracked display, and also a battery in my iPhone 3G. Worked great for a few weeks until the white screen of death started to appear when I press the menu button or the power button. Lately it is getting worse. I can get the display to work with persistance, but it's a pain.
I am wondering if maybe one of the cables is loose or something. I have taken it a part a few more times and disconnected and reconnected a few of the ribbon cables, (helps a little bit- but the white screen eventually returns) but I would like to know what ribbon cable corresponds to the display, or what part I can look at to see if maybe I reconnected it poorly.
anyone?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
2 Kommentare
Is this the part you're talking about? iPhone 3G/3GS Headphone Jack Assembly
von
no, I mean the ribbon cables that are labeled 1, 2, 3, 4, 5 and 6. like this one, for example:
http://s1.guide-images.ifixit.com/igi/pw...
von
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
Cable 1 LCD display
Cable 2 Touchscreen sensor and home button
Cable 3 earpice speaker and proximity sensor
4,5,6 are I believe GPS, antenna and camera cables.
That is what I can tell by opening it up.
War diese Antwort hilfreich?
Bewertung 6
6 Kommentare:
You are correct about most of them- However, 4,5 & 6 are actually dock connector, headphone/volume/power/vibration, and antennas, respectively. :)
von
Good to know Josh.
von
Very strange, I snapped part of the volume rocker cable (as we know connected to the earphone jack and power) now my home button isnt working, what do you think is up with that!? any help? thanks :)
von
This was very helpful. I am the kind of person who likes to check things before finishing up. I had the screen lose before tightening the last two screws and tried testing it but the home button was not working.
The reason the home button was not working was because it is connected once you push the screen in closed.
Once again, very helpful and good information. Thanks!
von
1 weiteren Kommentar anzeigen
the home button has it's own contacts that connect when the device is closed, it isn't fed through ribbon cable 2
Bewertung 4
2 Kommentare:
quite right, well spotted! +
von
I would advise people to be careful when opening and closing their iphone's, as i managed to break the little contacts off (both of them) and had to solder two small wires bent in a "U" shape, to replace the functionality of the previous contacts.
von
Although the home button is a separate entity and connects upon closing, if cable four is disconnected the it will not work.
Bewertung 0
sometimes the ribbon on the display lcd goes bad and you will get a white screan. replace full assemble should work . i had the same problem replaced the full lcd srean and it works great. good luck.
Bewertung 0
Antwort hinzufügen
James Elston wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 14
Letzte 30 Tage: 25
Insgesamt: 72,471
