display is only white
when turning on the PowerBook, i only get a white screen. i can hook up an external monitor and seen everything. When the startup cycle finishes, the display dims a bit. Is the display toast?
Ist dies eine gute Frage?
I am far more suspicious of the cable from the logic board to the LCD but it could be the LCD. The fact that you have a good picture on the external monitor would lead me to believe your logic board is good. Check out the cable carefully before replacing the LCD. Good luck Ralph
PowerBook G4 Aluminum 15" 1.67 GHz Display Assembly Replacement
[verlinktes Produkt fehlt oder ist deaktiviert: IF154-103]
War diese Antwort hilfreich?
agreed
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 666
