Zum Hauptinhalt wechseln
GSM iPad 2 mit 16, 32 oder 64 GB Speicherkapazität und einem Dual Core Prozessor. Modellnummer A1396. Die Reparatur ist schwierig und verlangt Hitze und Hebeln.
152 Fragen Alle anzeigen
Touch Screen (digitizer) tempramental after new one fitted?
Firstly I have now successfully removed and fitted over 50 new digitizers on Ipad's including 10 iPad mini's.
The one in question was bought to me after a failed DIY fix. I have attempted to fit 3 different digitizers that work perfectly in other machines but without success.
The problem is very temperamental, sometimes the touch screen will work perfectly and at others not. I have attempted to apply pressure at different parts of the PCB without change, the ribbon clips and connectors look ok under magnification and I have restored the devise back to factory setting and updated. Nothing makes any difference.
Be grateful for any help and advice - many thanks Dan
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
Hope it's not bad manners bumping my question?
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Assume the black fpc connector latch is faulty. Wedge some thin stiff plastic on top of flex and leave latch up. If this fixes it, you need a new fpc. If not, come back and we can look for missing continuity on the board
War diese Antwort hilfreich?
Bewertung 1
Hi Dan, try putting pressure on both the the digitiser connectors, and see if it works, keep putting pressure while your testing the digtizer
Bewertung 0
1 Kommentar:
Thank you for the advise Waseem,
I will give this another go but pretty sure I have already tried this. My first suspicions were that the connectors had been damaged.
I'll get back to you once I have investigated further - thanks again Dan
von
@ jessabethany - thank you for that I will give it a go and get back to you. :)
Bewertung 0
Antwort hinzufügen
Dan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 456
