Zum Hauptinhalt wechseln
Zweite Generation des CDMA iPad mit 16, 32 oder 64 GB Speicherkapazität und Dual Core A5 Prozessor. Modell Nummer A1397. Reparatur verlangt Feingefühl, Hitzezufuhr und Hebeln.
52 Fragen Alle anzeigen
ipad 2 not activating error
This is sorta a follow up to a previous question I had asked.(Replaced digitizer and antennas, still searching..)
None of the previous problems were fixed btw.
So we were instructed to restore the ipad to factory. Now we are getting the:
"Your iPad could not be activated because the activation server is temporarily unavailable. Try connecting your iPad to iTUnes to activate it, or try again in a couple of minutes.
If this problem persists, contact Apple Support at apple.com/support"
What do?
Ist dies eine gute Frage?
Bewertung 5
1 Kommentar
Mine to just after updating to 9.3 - totally bricked my iPad2
von
Einen Kommentar hinzufügen
5 Antworten
Hilfreichste Antwort
I would check for damage in the flex between the main board and the cell service board
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Hi Jessa,
Vortex's comment below seems to describe the problem I'm having on an iPad 4 which came to me for a battery replacement, it was re-booting every couple minutes.. New battery - No Change, Log files report temperature sensor failure on sensors 0,6 & 1. iPad wont Activate, displays "searching"
Question : if I can find someone that can replace the base band chip, will it function as normal..
Many Thanks
Paul
von
look into log files..
I think baseband temperature sensor fails working causing the part to shutdown, causing the device to reset, and so on
see also Nathan Rakes post, which ist the effect caused by this
Bewertung 1
I have seen this error many times on iphones with broken baseband chip after water damage or impact damages.
Itunes trying to read device's baseband chip (IMEI number or something like that) to activate the phone.
I guess same thing happening to your ipad CDMA. Baseband chip looks like not functioning.
Reasons
1- If its water damaged try to clean mainboard shortcuts and resolder corroded components.
2- if it has impact damaged, using hot air on the baseband chip may bring the baseband function back. I dont know What temperature and howmany minutes. But you can google for it.
Good luck ...
Bewertung 0
Hi.
How can i check the flex between board and cell service board?
I mean, if i check bouth sides of the flex i have continuty, but how can i check if the pads are soldered well?
Thanks?
Bewertung 0
What i want to do with my Ipad 2? Activation server is unavailable?
Bewertung 0
Antwort hinzufügen
Nathan Rakes wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 11
Letzte 30 Tage: 18
Insgesamt: 6,758
