Zum Hauptinhalt wechseln
The iOpener is an insulated, heat-retaining bag that can be heated in a microwave and used to transfer heat to the adhesive along the edge of an iPad or similar device.
23 Fragen Alle anzeigen
Hi, item does not get worm in 60sec
Hi,
It says that I have to heat up the iopener in 60sec but it does not get as warm as needed... I can almost hold it in my hand without it is to hot...
can I warm it in 2-3 min so that get useable?
My microwave works great...
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
4 Antworten
Gewählte Lösung
I thought the same thing about 60 seconds not really warming it much so I put it in for 2 minutes and it did not go so well. Do not heat it for more than 60 seconds.
War diese Antwort hilfreich?
Bewertung 4
3 Kommentare:
what happened?
von
Started smoking and slightly singed the microwave base. Also made me room and me stick of really badly burnt popcorn.
von
Had to throw the iOpener out as well because of the burned nature of the bag.
von
Only ever microwave the iOpener for 60 seconds at at time! If you find that the iOpener isn't quite warm enough after the first microwaving, go ahead and put it back in for another 30 seconds. It should be between 160F - 190F after that, and totally usable.
Bewertung 2
2 Kommentare:
Do you use an iOpener? I want to know because i was looking into getting one for repairs on iphones and other phones. Wanted to know how efficient the thing is!
von
For me it was more effective to use heatgun... so dont throw your money away...
von
Good old standered heat gun is the only job the I opener would never get it as warm as you need it
Bewertung 1
You only need it warm
Bewertung 0
Antwort hinzufügen
vk wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 6
Letzte 30 Tage: 15
Insgesamt: 1,140
