Zum Hauptinhalt wechseln
Model A1419 / Ende 2013 / 3,2 und 3,4 GHz Core i5 oder 3,5 GHz Core i7 Prozessor, ID iMac14,2
340 Fragen Alle anzeigen
compability 2013 iMac ssd
this SSD
[verlinktes Produkt fehlt oder ist deaktiviert: IF188-090]
compatible with my Imac 27 3.2 GHz late 2013?
Ist dies eine gute Frage?
Bewertung 1
1 Kommentar
These are used parts so they may not get any more.
von
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Sorry no.
The late '13 iMac's & Mac Pro systems use a M.2 PCIe SSD. So far Apple is the only supplier of these.
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
I spent an hour trying to get info on this and there's just nothing available yet.
von
I don't know if this is going to help, but I bought the one in the picture (1TB) from an eBay Mac seller and it worked.
Bewertung 0
I purchased one of these and it worked fine on my late 2013 14,2 27" iMac i was able to create a fusion drive with the standard drive utility in OS X 10.10.4 install
The Ebay ad contained this information
Apple OEM SanDisk SDNEP (655-1837D) 128GB with PCIe Interface
This will work in a MacBook Air Mid 2013 and 2014
This will work in a MacBook Pro Retina Late 2013 to 2014 13 and 15 inch
Also will work in the new iMac's SSD slot
Bewertung 0
1 Kommentar:
@Steve - As long as its a real Apple unit you should be fine. We tried getting a few about a year ago and out of the four we got only one worked! So be careful. Also note these drives are not larger than what Apple supplies in the system. You'll need to go to OWC or Transcend for these.
von
Antwort hinzufügen
info wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 5
Insgesamt: 1,508
