Zum Hauptinhalt wechseln
Herausgegeben im Oktober 2008 / 2,4, 2,53, 2,66, 2,8 oder 2,93 GHz Core 2 Duo-Prozessor
376 Fragen Alle anzeigen
keyboard is not responding after small water damage / repair
Yesterday, I spilled a small amount of tea on my MacBook Pro. it spilled mainly around the trackpad area and to the first row of keys, space and commend etc.
I turned it off, ejected the battery, stripped the computer, remove the logic board and removed the keyboard backlight panel and then dried the upper-case with a hair drier.
I also took out the touchpad and gave it a clean. Tragically, I tore the touchpad ribbon upon removal.
Current symptoms:
all systems work per normal except:
  • fans run non-stop
  • keyboard is totally unresponsive
  • obviously trackpad dead but new ribbon is on it's way.
what on earth happened in there? before stripping it completely after a dry, when I booted it up to test the trackpad, after about 20 seconds the volume started to go up by itself and I think random keys were being pressed.
what is my next move?
Thanks
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
the same thing happened to me , when a leak developed in my ceiling, dripping onto my open laptop all evening. i ended up replacing the keyboard on my late 2006 macbook pro.
rsrsparky
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
Matt Rowlands wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 332
