Zum Hauptinhalt wechseln
The first FWD car to be exported to North America by Volvo
How do I tighten my parking brake?
Currently, my parking break slows the roll of my car when I am in neutral. I need the majority of the stress to be on the break and not the transmission and my break is just not doing its job. It pulls all the way up and supplies little braking, if any. Is there a way to remedy this without taking wheels off?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
Nick,
Check this out from an 11 year Volvo mechanic, I would tend to go with that answer, even thought I didn't write it.
Regards,
Frank
War diese Antwort hilfreich?
Bewertung 2
2 Kommentare:
The method described there is the exact same as in my Saturn ION. Definitely the easiest way to make normal parking brake adjustments.
von
Park brake adjustment on 2004 jeep Cherokee - disc brakes ?
von
To adjust the tension screw in the center console, you'll need a Torx 50 bit (and a right angle attachment - it's a tight space).
Bewertung 0
1 Kommentar:
How do I enter the center console ?
von
Antwort hinzufügen
Nick Howell wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 7,152
