Zum Hauptinhalt wechseln
Rectangular Form Factor / 16 GB capacity / Announced September 12th, 2012
111 Fragen Alle anzeigen
How do I fix a loose Lightning connector?
My Ipod Nano's Lighting connector won't register when I plug it into my computer or wall charger. It dose respond however, if I push the Lighting part to the left of the plugin. What's the problem and how do I fix it?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
you can see iPod nano 7th tear down from ifixit
iPod Nano 7th Generation Teardown
and you will find it's not an easy task to fix the lighting connector. I think the lighting connector is soldered in the logic board, so if you want to repair or replace, you'd better send to repair center unless you own the professional equipment.
Good luck to you~
War diese Antwort hilfreich?
Bewertung 1
Antwort hinzufügen
Logan Thompson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 7
Insgesamt: 1,917
