Zum Hauptinhalt wechseln
Reparaturinformationen für den iMac G4.
130 Fragen Alle anzeigen
Can I put an Intel Mac Mini into a G4 Lampshade iMac?
I have been toying with this idea for a while and its about time that I do something about it... I want to make an intel mac mini powered Lampshade iMac...
I know its been done before but I cant seem to find the data or pinout sheets for the lampshad LCD display to DVI and I was wondering if anyone knows where I can find a guide on doing this? (I saw one a couple years back, but I didnt have a mac mini then...)
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 3
7 Kommentare
Hey Thanks a lot for the info! I'm sure something there will help me out!
von
good luck with your project, i hope that i could start mine soon - i halve almost everything here (didn't found the pervect optical drive - to bad that apple does not support bluray - but maybe i would use it anyway and fire up windows for this (my mini itx board has 2 vga and 1 hdmi out)
von
I want to know how it went too! I want to save my lampshade from the recycle bin - it's such a beautiful bit of industrial engineering.
von
So, I have to ask (because I just now had this same thought and this was the #1 hit on Google for my search): How did it go? Was the result worth the time and effort?
My experience to date in opening up Macs is primarily to add memory and change the clock battery, but I'm not shy about giving this a try on a 10 year old Mac that I personally think is the coolest machine Apple ever produced. I hate the idea of disposable technology, and this would at least keep a significant portion of the machine "alive."
Thanks - hope you're still getting updates from this thread. If you'd prefer to reply by email, I'm charliez # aol # com (replace punctuation accordingly).
von
Has anyone had luck with this?
von
2 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
This sort of thing has been attempted before but not for the feint hearted!
here are some links that may assist you
Link 1
Link 2
Link 3
Link 4 - this only uses case not the original LCD.
HIH and good luck!
War diese Antwort hilfreich?
Bewertung 3
1 Kommentar:
Shotgun repair. Something might hit ;-) +
von
It seems like this could help too.
Convert the header cable into DVI, fitting motherboard Intel in the housing ...
iMac G4 Mods
Bewertung 1
Antwort hinzufügen
Nathanael wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 10
Insgesamt: 18,650
