Zum Hauptinhalt wechseln
Repair manuals and information for the Microsoft Surface line of tablets.
128 Fragen Alle anzeigen
Can I repair a broken display without replacing it?
Hey guys!
I dropped my Surface RT what led to a broken glass in one of the corners.
The functionality of the touch display is not disturbed (except one little part on the left side).
As a new display is quite expensive i would not like to replace it.
But I am still afraid that some kind of moisture or water or sth. elese could get into the display...
My question is can i repair the broken point with some kind of glue or whats the best way to protect it from more damage?
Thanks a lot for reading this!
greetings Manuel
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
Manuel, there is really no way of fixing it. So, for a permanent resolution you will have to replace it. As a temporary solution you could use part of a screen protector to cover the area, or use clear double sided tape on that area only. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
Antwort hinzufügen
Manuel wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 558
