Where are the power on pads?
Where are the power on pads located on the macbook pro retina late 2013 logic board?
Ist dies eine gute Frage?
Asked and Answered. Some of the newer models do not have jumper points you have to short the keyboard connector block (do not have the keyboard connected when you do this).
If this answer is acceptable please remember to return and mark it.
War diese Antwort hilfreich?
Hi @machead3, can you please provide more detail on this, as I too have his problem and need to know the specific locations of the keyboard connector block and how to disconnect the keyboard (If this model doesn't have power-on pads)?
afoulds, there are power-on pads. If you ask your own question (not a comment)and add an image of your logic board with your question, I can point those out. Otherwise just shorten pin 5 of your keyboard connector to ground. Check on here Where are the power pads on this early 2013 MacBook Pro Model?
Ok Guys, for the MBP Retina late 2013, I come to found where is the power on pad located. I'm gonna upload the picture in a couple minutes
@doriservices you need to post your images with your question on here I ain't see them on mine (Power-on Pads)
Hello Tom how are you doing….?
Listen first of all you should troubleshoot your mac. And you should have know if the power cord is correct, the I/0 left on the Mac is working fine, and at last there are two pins on the witch gonna let power on the mac without the power button…..
Well, go check them and post the results surely
Hi Wilson,
yes, i am sure that the power cord is good
I found this site http://www.insidemylaptop.com/turn-on-ma... but I did not find the corresponding model to mine. So I do not know how to try to get started without the keyboard
OK guys here are your power on pads
they are in the yellow circle
How about for the 13" MBP Late 2013 Retina model?
Hi guys, where are power on pads MacBook Pro 2014 Retina display?
This are the same as the 2013 model i try and get the MBP to power on
Hello,
I have a macbook pro retina 13 inch (A1502 emc 2875 end 2013 to mid 2014). the mac does not start anymore. I can not find the handle for this model.
Could you help me
thank you
Letzte 24 Stunden: 3
Letzte 7 Tage: 12
Letzte 30 Tage: 42
Insgesamt: 14,103
1 Kommentar
I needed the exact location. I have diagrams for all but this model. The keyboard connector block on this model is not the same as the 2012.
von boo
