Zum Hauptinhalt wechseln
Zweite iPhone Generation. Modell A1241 mit 8 oder 16 GB Kapazität und schwarzer oder weißer Kunststoff-Rückseite. Die Reparatur ist leichter zu bewerkstelligen als beim iPhone 1. Es werden Schraubendreher, Hebelwerkzeuge und Saugnäpfe benötigt.
1158 Fragen Alle anzeigen
My iPhone is just dead...
Hi, My iPhone just died !
Even after charging it for over 12 hours I couldn't start it again. The technicien at Appele asked over 200€ to fix it - claiming there is humidity in the phone & it's not under gurantee........
What can I do ? How can I fix that ?
Thanks for your help,
Avi
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
I would use a guide from here and disassemble it. the needed parts are listed in the guide.
once the phone is apart, look out for white/green/black stuff that looks "odd".
clean it with ipa and a soft paintrbrush, let it dry and the reassemble it - in case you have a multimeter, measure the battery if it has around 3,7v
War diese Antwort hilfreich?
Bewertung 2
5 Kommentare:
markus,
What is the setting I should use for the multimeter to test the battery strength?
Thanks.
von
you can only measure the voltage - most multimeter have a 20v setting, that would be the right one.
von
Thank you markus for the answer. I've forgotten to ask what readings would mean the battery needs to be replaced? Also, should the battery be read when it is fully charged, drained, or does not matter?
Thanks again.
von
it doesn't matter - the voltage should be around 3.7v - if the battery has something like 3.4 - the phone won't start up.
von
what pins do you touch with the multimeter?
von
Antwort hinzufügen
AVI wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 1
Insgesamt: 1,684
