Zum Hauptinhalt wechseln
Clothes dryer repair and support guides.
871 Fragen Alle anzeigen
Maytag Bravos Quiet Series 300 Electric Dryer squeaking?
I have a Maytag Bravos electric dryer that has recently been periodically squeaking when in operation
So far it is not constant but has not done this before
It's about 4 years old
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Rick is describing a squeaking noise, typically a frayed belt doesn't cause this very common dryer problem. The drum sits on a set of rubber rollers attached to posts located on the back and occasionally the front of the dryer. These rollers (they look like an in-line skate wheel) sometimes need replacing, but more often than not you can just clean them up with a little steel wool and lithium grease.
War diese Antwort hilfreich?
Bewertung 2
It's a little early for bearing to be wearing out. I'd check the:
Drive Belt
If the dryer makes noise, the belt may be frayed or damaged. If the belt is damaged, it will make noise every time it travels around the pulleys. The drive belt is a long, narrow band that wraps around the entire drum, then around a tension pulley and the motor pulley.
Bewertung 1
Antwort hinzufügen
rick wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 2,831
