Zum Hauptinhalt wechseln
Model A1046 or A1095 / 1280x854 screen resolution
118 Fragen Alle anzeigen
Hard drive cable plug in
Hi,
I guess I screwed up putting in a new 120GB hard drive. The computer doesn't see any hard drive. I was more concerned about removing the cable from the hard drive without bending any pins and I think I plugged it in wrong. There are 2 rows of pins on the left side of the pins and then a space and I am not sure if I start the cable there or skip those 2 rows and plug it in? Thanks.
Thanks...I went to the other side...Will switch it tomorrow when I am more focused and not bummed
I opened it up again and everything was connected correctly. Did this a few more times since it still would not see the HD. The last time as it started the install and no HD to put it on I went to the Utility program and it saw the HD. I erased it and started the install. It is going along well.
Thanks to all for the help.
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Gewählte Lösung
Hi! I pasted in a link below to a picture of the pins on a hard drive. Looking at the picture, you want the plug to cover the big chunk of 2 rows of pins on the right side. If that means the 4 pins to the left that are separated by a space are not connected to the plug, that is fine -- some plugs cover the additional pins, and some don't.
http://www.datarecoverytutorial.com/wp-i...
War diese Antwort hilfreich?
Bewertung 1
1 Kommentar:
Also notice the missing pin. You should have a blank spot on the connector that fits that spot. Ralph
von
Antwort hinzufügen
andersong wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 12
Insgesamt: 1,686
