How to stop my cupboard doors from swinging open
What kinds of latch is best to secure my kitchen cubbord doors so they stay shut?
Ist dies eine gute Frage?
Depending on the age of the cabinet you could have a pin that meets a socket where the socket spring is worn. the next generation is a roller that has a spring with in it that hits a catch on the frame. The newest versions have a claw that catches a pin or a magnet. Lastly the hinge its self could have a spring in it to hold the door closed.
Depending on what you have the best solution is to replace with the same type. I would go to a local hardware store with the pieces of what you have now and try to get a newer set.
Sometimes the mounting points (screw holes) are worn or stripped out:
If you want to change out the catch I would go with a magnet type. The only problem here is they are not very strong so anything pressing against the door if over stuffed will pop it open unlike the mechanical models. Or if you can switch-out the hinges with the spring type that hold the door closed.
War diese Antwort hilfreich?
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 2,982
1 Kommentar
Julie add an image of your cabinets with your question. That would help us to see how the doors are constructed and we could help a bit better.
von oldturkey03
