Zum Hauptinhalt wechseln
Reparaturanleitungen und -Informationen für die Apple Mighty Mouse. Diese Maus ist mit einem Lasersensor, vier Tasten und einem Trackball ausgestattet.
scroll ball only works in one direction
I have a mighty mouse and the scroll ball only works in the right to left direction. In older mechanical mice, every so often you needed to take the ball out and clean the wheels that the ball touched on the inside. How can I safely take the cover off the mighty mouse and check to see if the inside needs cleaning?
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
4 Antworten
Hilfreichste Antwort
There's another answers topic on this subject here.
War diese Antwort hilfreich?
Bewertung 1
First, try a lint-free cloth with a little isopropyl alcohol or similar on it and rub the ball with it in all directions for a while. Works nearly every time. When my mouse acts up i'm sometimes a bit sloppy and just rub it over my trousers which works just as well.
Bewertung 0
Eventually even the trouser trick wont work. Follow these images to see what you need to do. Its not that hard, but you need a little glue when you are putting it back together.
http://www.applematters.com/index.php/ga...
Bewertung 0
use a vac over the ball
Bewertung 0
Antwort hinzufügen
Paul Watson wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 7,217
