Zum Hauptinhalt wechseln
The 7 inch third generation of Nook color tablets by Barnes & Noble, not to be confused with the 9 inch Nook HD+.
30 Fragen Alle anzeigen
Why is my Nook HD's screen unresponsive?
My screen is on, but displays nothing or is unresponsive to touch.
Ist dies eine gute Frage?
Bewertung 12
Einen Kommentar hinzufügen
3 Antworten
Hilfreichste Antwort
Frank Poole, I am wondering if it is the same Nook HD from your other question. There is the possibility that you will need a new display, check your other question for the how to etc., If it is a different one, you may want to try a Factory Reset and see if that will help. "Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. From here. Hope this helps, good luck.
War diese Antwort hilfreich?
Bewertung 2
In addition to oldturkey03's advice I recommend checking out the nook HD troubleshooting page: Nook HD Troubleshooting.
Bewertung 1
Don't do a factory reset til uve backed everything up or moved it to an external sd card! U will lose everything! Mine has this same issue. The battery would start to heat up, which I've read happens frequently with nooks, & becomes unresponsive/freezes. I just shut it down, wait about 15 min or so til it cools down. When its turned back on its fine.
Bewertung 0
Antwort hinzufügen
Frank Poole wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 8
Letzte 30 Tage: 17
Insgesamt: 8,811
