Zum Hauptinhalt wechseln
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
169 Fragen Alle anzeigen
I have a stripped case screw... how do I remove it?
I'm trying to follow the Vita 'replace the left joystick' guide and ran into a problem - I can't remove one of the screws on Step 1. I was able to remove the other 7 case screws, and even reach in to unplug the battery and touch screen cables, but...
... I'm worried that I can't just force it apart without damaging the right button board. What do I do?
Ist dies eine gute Frage?
Bewertung 2
Einen Kommentar hinzufügen
1 Antwort
Get a dollar-store eyeglass repair kit that contains those tiny screwdrivers. Select the best fitting one, and dip the point of the screwdriver into a drop of superglue (not so much that you end up gluing the damaged screw into the housing). Glue cheap screwdriver onto damaged screw, and when the glue has set, lefty-loosey and away you go.
War diese Antwort hilfreich?
Bewertung 0
Antwort hinzufügen
rayhaven5618 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 3,548
