Zum Hauptinhalt wechseln
The HTC One X is the first HTC phone to be equipped with a quad-core processor, released in April 2012.
My HTC One X screen has just gone blank...
My HTC One X was working perfectly fine but then suddenly the screen went black. I tried connecting it to the charger but the red charging light wouldn't come on. I also tried ringing the phone but nothing happened. I tried holding the power button for about 15 seconds, still no response. The final thing I tried was to connect it to the computer to see if the computer would detect the device however the computer didn't. I don't know what else to do, HELP?!?
Ist dies eine gute Frage?
Bewertung 13
8 Kommentare
keep holding the power button and the volume up it worked for me
von
Thank you , Yasa. A great fix. Did the trick !
von
@Yara Mansour I love you rn I you are my life tbh
von
This totally saved me! Thanks!
von
hey guys it worked forme too. since yest night ithad this issue suddenly turned blank. when called said switchoff. but could get whatsapp call, but could not attend. alarm was ringing but could not slide to off. but this trick worked thks very much
von
3 weitere Kommentare anzeigen
Einen Kommentar hinzufügen
6 Antworten
Hilfreichste Antwort
Mine blanked too! This twist thing (below) actually worked:
http://www.htconeforum.com/forum/htc-one...
War diese Antwort hilfreich?
Bewertung 1
2 Kommentare:
Great!! Twisting got my black screen problem solved! Thank you for sharing :)
von
i have the same problem , Adinda Adinda how solved black screen problem
von
It seems your phone died for broken motherboard or battery, you need to send for professional check.
Bewertung 0
1 Kommentar:
Are the local phone repair shops fine? And do you know how much they will charge to repair it.
von
You have what's know as the black screen problem, ( I have too) there is a fix but it involves taking the phone apart and putting a bit of paper between a ribbon cable bend. I'm looking for the fix again myself. In the meantime I bought a new phone LG G2, (good phone recommended) I'll post back here once I find the fix, but it's not for noobs.
Found it: http://www.htconeforum.com/forum/htc-one...
Bewertung 0
hameed_kakar2003@yahoo.com
Bewertung 0
mine was taken back to china.apparently not even flashing wold help and no one knew wat the !&&* was going on.am still waiting for my phone
Bewertung 0
How to fix htc one x overheating? Touchscreen sutting down automaticly
Bewertung 0
Antwort hinzufügen
Haroon wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 9
Letzte 30 Tage: 18
Insgesamt: 42,890
