Zum Hauptinhalt wechseln
Vierte iPhone Generation. Die Reparatur an sich ist unkompliziert, aber Frontglas und LCD müssen gemeinsam ersetzt werden. GSM mit 8, 16 oder 32 GB Kapazität, Modell A1332 in schwarz und weiß.
2375 Fragen Alle anzeigen
My vibrator and proximity sensor is not working
Hey
My friend gift me one iphone with broken display and proximity sensor, so i bought one from ebay and i assembled it, but the sensor is still not working.
Also i recently noticed my vibrator was not working and so i removed another from dad's iphone and used it but still nothing
im from italian, sorry for my english :)
Ist dies eine gute Frage?
Bewertung -1
Einen Kommentar hinzufügen
2 Antworten
Hilfreichste Antwort
Cut two hole out of the electrical tape and place over the sensors
War diese Antwort hilfreich?
Bewertung 1
5 Kommentare:
but it is weird because if i tap it with finger light should not pass
von
Look I'm giving you advise that is tryed and tested and works if you choose not to take that advise no problem
von
If you have changed the vibrate motor and it's still not working you need to change the volume , mute and headphone jack flex that's were the vibrate motor gets it's power from.. As for the proximity not working it's possible that to much light is getting in and causing the sensor not to work .. I simply use the electrical tape trick to fix this
von
what is that electrical tape trick ?
von
im not saying it is wrong :) i just want to be sure it is not anything else before disassembly the iphone again
von
If the proximity sensor still isn't working, you may need to replace the power button and sensor.
While you've got it open you may want to replace the vibrator with a brand new one. iFixit has them for only $9.95
iPhone 4 Vibrationsmotor Bild
Anleitung
iPhone 4 Vibrationsmotor austauschen
Schwierigkeitsgrad:
Mittel
20 - 40 minutes
iPhone 4 Versorgungs-/Sensorkabel Bild
Anleitung
iPhone 4 Versorgungs-/Sensorkabel austauschen
Schwierigkeitsgrad:
Schwierig
1 - 2 hours
Bewertung 0
1 Kommentar:
i already tryed one working vibrator but still not working
so about power sensor i need change cable? hm it looking hard this part
thank you for the rapid ansewer :)
von
Antwort hinzufügen
Nikkolo wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 2
Insgesamt: 199
