Zum Hauptinhalt wechseln
Repair information for Bosch dishwashers.
Bosch dishwasher has no power
My friends Bosch dishwasher model Model Number: SHE68M05UC/50 has no power. We checked the power source with a voltmeter and it said 120. Then we follow it up and checked the on and off switch that was ok then we checked the door lock switch and that seemed ok. Then all of a sudden it had power so we unplugged it from the extension cord hooked everything back up and plugged it back in and now there is no power again. We are stumped can anyone help???
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
2 Antworten
Gewählte Lösung
does it have a sealed for life plug ? set the meter to continuity and check the continuity from the plug pins to the mains in on the machine ,if you have continuity your problem is further on !
hope it helps .
War diese Antwort hilfreich?
Bewertung 0
Hilfreichste Antwort
Check the wall plug with a lamp or a toaster. If no power, flip the breaker switch in your electrical panel.
Bewertung 1
1 Kommentar:
Thanks for the tip but w we tried it there is power coming from the wall and we tried the breaker.
von
Antwort hinzufügen
Jamie wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 12,202
