Alisja, take a look at this diagram
1. sunroof glass W/SUNROOF
2. sunroof glass bolt W/SUNROOF
3. glass w'strip W/SUNROOF
4. sunroof frame W/SUNROOF
5. sunroof frame pad W/SUNROOF
6. sunroof frame stopper W/SUNROOF
7. guide W/SUNROOF Left
7. guide W/SUNROOF Right
8. drip channel W/SUNROOF
9. drip channel plate W/SUNROOF Right
10. air deflector W/SUNROOF
11. motor W/SUNROOF
12. sunshade W/SUNROOF, gray
13. sunshade handle W/SUNROOF, gray
14. drain hose W/SUNROOF, front Left
14. drain hose W/SUNROOF, front Right
15. drain hose W/SUNROOF, rear Left
15. drain hose W/SUNROOF, rear Right
16. drain hose clip W/SUNROOF, front left
16. drain hose clip W/SUNROOF, front right
17. drain hose clip W/SUNROOF, rear Right
17. drain hose clip W/SUNROOF, rear Left
18. drain hose grommet W/SUNROOF Left
18. drain hose grommet W/SUNROOF Right
See if those are the parts that you are referring to.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
