Zum Hauptinhalt wechseln
Android 4.0 tablet for children/ blue back cover and white face/ released 2012
The touch screen is unresponsive
I keep pushing on the touch screen but nothing moves? What should I do?
Beantwortet! Antwort anzeigen Ich habe das gleiche Problem
Ist dies eine gute Frage?
Bewertung 5
4 Kommentare
It will work with A mouse
von
the glass is cracked will this keep it from working
von
It isnt working not alittle.
von
my screen is cracked and the same thing happening how do I fix this
von
Einen Kommentar hinzufügen
3 Antworten
Gewählte Lösung
The most likely problem is a loose connection on the inside.
Check the connections of the ribbons on the inside of the device. Follow the motherboard removal guide to get to the ribbons.
If this doesn't work, the digitizer may need to be replaced. However, a guide is currently not available for that. To replace the digitizer, one would follow steps similar to the screen replacement guide, but put the components in a new digitizer.
Kurio 7 Bild
Anleitung
Kurio 7 Motherboard Removal Guide
Schwierigkeitsgrad:
Schwierig
15 - 25 minutes
Kurio 7 Screen Bild
Anleitung
Kurio 7 Screen Replacement
Schwierigkeitsgrad:
Mittel
30 - 45 minutes
War diese Antwort hilfreich?
Bewertung 5
1 Kommentar:
my tablet is in a sleep mode and will not wake no matter what I do.
Tried on and off, reset button and power and up volume button at the same time and nothing changes
von
Mine is the same as Amos. Sleep mode . Wont wake up.
Bewertung 0
Chicken
Nugget
Watermelon
Bewertung 0
Antwort hinzufügen
Omri Nissan wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 9,345
