Zum Hauptinhalt wechseln
Released June 2012, identified by model number 3560.
8 Fragen Alle anzeigen
SSDm Sata install tutorial
How can I install a new SSD mSata on my Vostro 3560?
Ist dies eine gute Frage?
Bewertung 1
Einen Kommentar hinzufügen
1 Antwort
Hilfreichste Antwort
There's a daughter board that comes off the main board. Check the Vostro 3560 OM, here. You can see it on Pg. 37. If it does not have the mSATA slot underneath it (opposite of the WLAN card), then you'll need Dell P/N 82PYC. (here's a cheat I know of. If you look in the OM on PG. 23, the last illustration on the page, if you take the bottom cover off the laptop, directly underneath the battery latch, there's a small window in the plastic. If you look in it, you can see the edge of the mSATA socket. If you don't see the socket, you won't have hte correct daughter board, and will need the Dell P/N listed above to add mSATA.
War diese Antwort hilfreich?
Bewertung 5
2 Kommentare:
I have two divers that came with the laptop;
@ Liteon it LMS - 32L6M mSATA 32GB (where the operating system and softwares installed on)
@ WDC WD7500BPKT-00PK4T0
Currently, the 32GB is too small and its making my cumbersome. So I want to replace it with a 250GB Crucial -sata ssd. But I have failed to locate where the 32GB sata drive. Can someone help….
von
Dell Vostro 3560 Model
von
Antwort hinzufügen
pedromaia87 wird auf ewig dankbar sein.
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 5,375
