How Can I repair an overheating iBook G4
It feels like my iBook G4 14" 1.42 GHz is overheating and freezing up. What is the problem and can somebody assist me?
Ist dies eine gute Frage?
Here are some other things to try. Good luck Ralph
War diese Antwort hilfreich?
research +
I'd open it, blowing out the dust, and replacing/repairing the thermal paste.
Dust accumulates on the fan blades and settles on the board and parts. Sort of insulating the board and reducing the efficiency of the fan. The thermal paste dries out reducing it's efficiency
BE CAREFUL when you blow out the dust and remove replace the paste... or you could short out the board.
N.
Agreed +
You need to run some diagnostics, first, you should download iStat Pro and check your fan speeds. Second, use Disk Utility (/Applications/Utilities) to verify your startup disk. Please also describe what exactly starts these freezes and what are the symptoms.
Some easy fixes you might want to try would be to reinstall the OS and reseating the RAM.
Ask no questions in answers! Put questions in comments - isn't that your rule?
"Some easy fixes you might want to try would be to reinstall the OS and reseating the RAM."
I'd now ask you to kindly remove your downvote
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 2,831
1 Kommentar
Are you sure your fan is working ? Do you hear it spinning when doing an intensive job ?
von lemerise
