First Bookmark this site in your browser.
Icemaker Mold Thermostat
If the ice maker is not working the icemaker mold thermostat might be defective. Inside the control module of the ice maker is a thermostat which monitors the temperature of the ice mold (ice tray). Once the mold reaches the proper temperature the ice maker starts a harvest cycle by ejecting the ice cubes and refilling with water. If the mold thermostat is defective the ice maker doesn't advance. The thermostat can be checked for continuity. (See if it is closed). Replace it as needed.The freezer temp should be between 0-5 degrees for optimum performance.
Icemaker Switch
If the refrigerator ice maker is not working, check the icemaker switch. This switch frequently gets turned off by accident. If the switch is turned on but the ice maker still doesn't work, check the switch for continuity with an Ohm meter. Replace as needed.
Ice Level Control Board
If the ice maker is not working the ice level control board might be defective. This refrigerator is equipped with an infrared light beam to detect the level of ice in the ice bucket. As the level of ice reaches the top, the beam is interrupted and the ice maker shuts off. As ice is used up and the level of ice drops below the beam, the ice maker starts up again. If the ice level control board fails, the ice maker will stop making ice.
Door Switch
If the refrigerator ice maker is not working, the door switch might be defective. When the freezer door is opened the freezer door switch does two things, it turns on the light in the freezer and turns off the ice maker and dispenser. If the door switch fails the dispenser will not turn on. The switch can be checked for continuity with an Ohm meter. If it doesn’t have continuity it should be replaced.
Icemaker Module
If the ice maker is not working the icemaker module at the front might be defective. The module has a motor that cycles the ice ejector arms around to push the ice cubes out when the ice maker thermostat closes. It also has contacts in it for the mold heater and water inlet valve. The motor or contacts of the module can fail. Usually there are test points in the module that a service person can use to determine if there is a problem with it or one of the related ice maker components.
War diese Antwort hilfreich?
Bewertet
Rückgängig machen
Bewertung
6
Abbrechen
Schau durch den Thread, bis du den richtigen Platz für diesen Kommentar gefunden hast. Klicke dann auf "Den Kommentar diesem Post zuordnen", um ihn zu verschieben.
7 Kommentare
We have the same problem...any help out there?
von timro2000
timro, how much more help do you need than the answer I gave?
von mayer
Can anyone help daewoo model frs u2dci. Makes the ice but doesn't dump it out
von Susam
report to your state attorney general office of consumer complaints...I'm tired of new expensive products not working days and weeks after purchasing!!! Need class action suit maybe.
von Mary Hall
Just remember, your State Attorney General is not there to protect consumers.
von Paul McKelvey
2 weitere Kommentare anzeigen
